12.2 RC2 - Build #12.2.0.9011 is now available for testing. If you noticed any bugs in RC1 or the Beta you may want to take a look.
Hey guys, just want to let you know that 12.2 is generally available now! You can find it on your customer portal (http://customerportal.solarwinds.com/) or on www.webhelpdesk.com.
It seems like 12.2.0 has broken redirects to the SSL port (ex. visiting http://helpdesk.example.com would automatically redirect to https/helpdesk.example.com). I had this setup prior to upgrading and have combed through documentation but can't get redirects to work anymore. Am I missing something or is this coming in the full release?
Let us try to reproduce this, we did not touch this functionality, so it should work. (Tracking under # 390165 internally)
Any news on this feature?
Check in your \webhelpdesk\conf\whd.conf file and check that you have the following variable and that it is set as following;
NO_REDIRECT=false
