Greetings, we did a ssl replacement through the portecle, following the instructions for the .pfx import to the keystore, but after that the site wouldn't load at all, the logs show this section below that I think is the problem. We restored the backed up keystore file and the site was able to load again, albeit with the expired certificate. Since the path of the keystore is fine it doesn't seem to be that, but not sure what other logs to check.
ERROR [2022-08-31 10:17:33]<CommonDaemonExecutor-thread-1> Error while triggering session in com.macsdesign.whd.daemon.ServletPulseDaemon: java.net.ConnectException: Connection refused: connect
Appreciate any ideas!
