Hi !
i'm new and i just install Orion version 7.3.2 with success.
I have to install the 7.1.1 version , i need sql server 2005 for it. After installation i have to configure solarwinds, and i got a problem for the database settings.
An error message tell me the following statement :
" you are attempting to use an unsupported version of SQL Server.
Please select a database on a sql server using any of the following supported Microsoft SQL Server Express, Standard or Entreprise versions :
SQL server 2005 SP1 or later (32 bit or 64 bit )
SQL server 2008 RTM or later (32 bit or 64 bit )
SQL server 2012 RTM or later (32 bit or 64 bit )"
thanks u !
