SNMP v3 is not correctly authenticating for ethernet devices but will for ATM devices. Switch/router snmp-server, user, group configs have been double, triple checked as well as the SolarWinds credentials but we cannot get them managed via SNMP v3. Have also ruled out ACLs, firewalls essentially any type of filtering.
However, our ATM Devices are managed via SNMP v3 and work as intended.
This is the error message we receive: "SNMP Validation Failed for Node 'X' - Error: SNMPv3 - Wrong Digests - The authentication digest did not match to the expected result, possible incorrect key/password."
And as stated above, the credentials have been checked multiple times over and removed and replaced.
Any help would be greatly appreciated, thank you.
