I want to create below type alerts for the SQL server. Can anyone help me with the steps.
- Unauthorized access or Authentication failed to the database or the server (maybe collected from the Log file )
- Log file size is more than 20GB (For example ).
- If Disk is low on space it should send an alert with the solution and what particular file/folder is consuming more space.
Also what are other alerts i can set for the SQL servers. Something like Critical.
