I'm having an error on our web pages where the Orion map Icons are VERY basic and the network background is completely missing with a white background. I have a case number opened (1141747) but the steps provided where to recreate website, Clear ASP.NET, repaired core installer, and re-ran configuration wizard.
Some background:
We moved Solarwinds from Windows2008r2 to Windows2012r2 and I went through the migration process. Everything works great except the maps... Load up Network Atlas and it recognizes the maps just fine. I even went and built a fresh map with a few nodes on it and tried to test that but no success either.
Here is a brief on the error I'm receiving from the orionweb.log file:
WARN MapEngine - (null) Failed to dispose map objects
System.Runtime.InteropServices.InvalidComObjectException: Com
object that has been separated from its underlying RCW cannot be used.
at System.StubHelpers.StubHelpers.GetCOMIPFromRCW (Object objSrc, IntPtr pCPCMD, IntPtr& ppTarget, Boolean& pfNeedsRelease)
at TomSawyer.TSGraphEditor.get_mainDisplayGraph()
at
AxTomSawyer.AxTSUnicodeGraphEditorControl.get_mainDisplayGraph()
at Solarwinds.MapEngine.MappingControl.get_MapObjects()
at Solarwinds.MapEngine.MappingControl.MapClose()
This is also on a network where I can't "Pull" logs from...If anyone can help with this I would greatly.
