I am trying to understand the benefits of Virtualization Manager over what the Virtualization tab in NPM provides. Can anyone help me with this?
NPM mainly gives you health and status information of the VM and hosts, but not deep insight into the configuration, performance or contention within the virtual infrastructure (VMware and HyperV). Virtualization Manager also has features like Capacity Planning, Time Travel, Object DNA, Chargeback, Cloud Cost Calculator and much more.
You can try the Demo Site to see the features, review our website to get more details, or download and install to try it yourself.
Let me know if you want further info.
Brian
Will the installation of Virtualization Manager replace the NPM "Virtualization" tab or just add additional components and features to the existing tab? Thank you.
Tim
No, its a virtual appliance for VMware or HyperV, but you can add a custom resource to integrate any widgets to NPM dashboard, like this.
Hi Tim,
With VMAN 6.0, there is now deep integration between VMAN and NPM/SAM Virtualization that extends the Virtual Infratrustructure data provided by NPM and SAM. It does not replace the data. A full Product Blog post on the integration should be forthcoming within the next 72 hours with further detail. In the meantime, you can check out the Beta Blog Post for VMAN 6.0.
