I want to be able to add asset information to nodes that are either unmanaged (not polled) or polled via ICMP.
Reason: I have a boatload of hardware that I need to report the warranty status on that I do not have credentials for (systems span 2 divisions, 4 states, and 20 sites).
Adding info manually would suffice, but programmatic import would be better (upload csv, powershell, sql script).
Background: The 2 divisions had different ways of running their IT departments, so there wasn’t a lot of consistency setting up these systems. Polling has been a challenge. I thought that if I could just get the systems in via ICMP polling, I could manually enter the warranty info into the [AssetInventory_ServerInformation] table. But nodes aren’t added there for un-credentialed polling. SNMP polling does populate that table after rediscover, but the Nutanix MIB doesn’t seem to include the hardware serial number. So I still need to enter in [HardwareSerialNumber], [Manufacturer], [Model], & [WarrantyDate] manually into the table for each system (I back up the db frequently).
USE [SolarWindsOrion]
GO
UPDATE [dbo].[AssetInventory_ServerInformation]
SET [HardwareSerialNumber] = 'xxxxxxxxxx',
[Manufacturer] = 'Nutanix Inc.',
[Model] = 'NX-1175S-G6',
[WarrantyDate] = '2022-12-31 23:59:59.000'
WHERE [NodeID] LIKE '11111';
