This is the reason we got rid of using the agent. The only option for autodiscover and import of changes is to check the box that says "Check all existing nodes polling with agents for node changes and updates " in Network Discovery. The problem is our team has our own nodes that use Linux Agents, but we have a windows team with their own nodes using Windows agents. Why should us checking this box that would be good for us, force their team to also accept the setting for their nodes?
so our only option is ALL or NOTHING. And if you do not check this box, you will have to go into each and every of your thousands of nodes and check "List Resources" before anything will be monitored.
Please allow us to more fine-tune what is updated via agent and what is not.
Thanks!
