Hello Thwack community, when I try to run a firmware upgrade to a certain node, I am having the following issue by copying from polling engine tftp server the image and uploading it into the flash of my cisco switch 9300.
copy tftp://[IP ADDRESS]/SUB-FOLDER/cat9k_iosxe.17.09.04a.SPA.bin flash:
Destination filename [cat9k_iosxe.17.09.04a.SPA.bin]?
Accessing t10.195.29.173/.../cat9k_iosxe.17.09.04a.SPA.bin...
%Error opening tftp://[IP ADDRESS]/SUB-FOLDER/cat9k_iosxe.17.09.04a.SPA.bin (Timed out)
ERROR: Process could not continue because execution results do not match expected pattern: cat9k_iosxe.17.09.04a.SPA.bin
Does anybody knows what might be wrong? Seems that the expected pattern is not correct, but the image is available in the firmware repository.
