Hello Thwackers -
Is there a way to have an object link to a custom URL... e.g. put a group on the map and have it link to a different map instead? That or if I put an Orion Map as an object in another Orion Map, have that Orion Maps status icon adjust itself based off the objects in that map?
I've been testing out the functionality of Orion Maps and have discovered a lot. Our goal is to have services and their supporting nodes / applications members of groups that are mapped in an Orion Map. Each service will have their own service map and then their will be a high level service map just showing a status icon of each service.
This brings up a good question... how are Orion Maps status calculated and under the hood is it just a group? E.g. might I consider it as a Mixed-Mode status group or Show best status etc..?
