Hello Thwackers,
It would be a great help if someone provides me the solution for OSPF alert configuration.
NPM has out of the box alert for OSPF Neighbor State change based on the SNMP Polling( using OID - 1.3.6.1.2.1.14.10 to get OSPF neighbor states).
But what i observed is if any OSPF neighbor went down, the entries also disappear in the OSPF routing table(show ip ospf neighbor) and this makes solarwinds will get only either FULL or TWOWAY OSPF neighbor state entries and there will be no alerts for other states.
Can someone please explain how you are monitoring OSPF neighbor state changes?
Karthik A
