Considering DHS Emergency Directive 21-01, which requires (Appendix B, item 8), "The SolarWinds Orion server, the web server, and the database server instances must be installed on separate and dedicated hosts," is there a way to run the centralized upgrade using an offline installer from an alternate web server instead of the 'SolarWinds Orion' server? If so, how? Have any of you pulled this off?
