HI All
Trying to do a select via the SWQL studio
SELECT+NodeID,NodeCaption,NodeGroup,AgentIP,Community,SysName,SysDescr,SysContact,SysLocation,SystemOID,Vendor,MachineType,LastBoot,OSImage,OSVersion,ConfigTypes,LoginStatus,City+FROM+NCM.Nodes
But as a result I get -
2020-06-30 09:14:37,930 [154] ERROR SolarWinds.InformationService.Core.InformationService - SWQL Studio (null) Exception caught in method SolarWinds.InformationService.Core.InformationService.RunQuery
SolarWinds.Data.SWQL.SWQLSyntaxException: no viable alternative at input 'FROM' in Select clause ---> Antlr.Runtime.NoViableAltException: A recognition error occurred.
at SolarWinds.Data.SWQL.Parser.SWQLParser.unaryExpression()
--- End of inner exception stack trace ---
at SolarWinds.Data.SWQL.Parser.SWQLParser.multiplyExpression()
at SolarWinds.Data.SWQL.Parser.SWQLParser.additiveExpression()
at SolarWinds.Data.SWQL.Parser.SWQLParser.relationalExpression()
at SolarWinds.Data.SWQL.Parser.SWQLParser.equalityExpression()
at SolarWinds.Data.SWQL.Parser.SWQLParser.negatedExpression()
at SolarWinds.Data.SWQL.Parser.SWQLParser.logicalAndExpression()
at SolarWinds.Data.SWQL.Parser.SWQLParser.logicalOrExpression()
at SolarWinds.Data.SWQL.Parser.SWQLParser.expression()
at SolarWinds.Data.SWQL.Parser.SWQLParser.aliasedExpression()
at SolarWinds.Data.SWQL.Parser.SWQLParser.selectedPropertiesList()
at SolarWinds.Data.SWQL.Parser.SWQLParser.selectClause()
at SolarWinds.Data.SWQL.Parser.SWQLParser.selectFrom()
at SolarWinds.Data.SWQL.Parser.SWQLParser.queryRule()
at SolarWinds.Data.SWQL.Parser.SWQLParser.selectStatement()
at SolarWinds.Data.SWQL.Parser.SWQLParser.statement()
at SolarWinds.Data.SWQL.SWQLParser.Parse(String query)
at SolarWinds.Data.Query.Engine.QueryProcessor.ProcessInternal(String query, IQueryExecutionContext context)
at SolarWinds.InformationService.Core.QueryPlanCache.GetQueryPlan(String query, String username, Boolean federationEnabled, Func`1 buildQueryPlan)
at SolarWinds.InformationService.Core.InformationService.RunQuery(String query, IDictionary`2 parameters, IDataSerializer serializer)
!some searching leads to this, but yes not quite the answer but maybe something to do with the version we are running
https://thwack.solarwinds.com/t5/EOC-Discussions/EOC-Not-Accepting-SQL-Filter-Queries-for-Custom-Properties/m-p/193354
We are running version 12.4 of the NPM
Orion Platform 2018.4 HF3, IPAM 4.8.1 HF1, NCM 7.9, NPM 12.4, NTA 4.5.0, VMAN 8.3.1, NetPath 1.1.4
1999-2020 SolarWinds Worldwide, LLC. All Rights Reserved.
Is there someone out there who can help me in some way
Thanks in advance
