For the longest time, we have been having a problem with our machine that houses our SolarWinds Orion/NPM database. Every five minutes or so, the CPU utilization spikes up to 100% and stays there for a few minutes before going back down again. Five minutes later, its back at 100% again. This has been happening ever since we've started to use NPM and setup the machine for it. I've tried a lot of different things to fix it, none of them worked.
After doing the smart thing and monitoring the activity on the SQL server, I found out whats probably causing the problem: the stored procedure for getting the current values of settings for SolarWinds Orion (sw_GetSettingsCurrentValue) is being ran thousands upon thousands of times (see attached) and I can't figure out for the life of me why.
Is there something up with my Solarwinds installation that needs to be taken care of? Is there some setting that got messed up during setup?
