We are planning to install Solar Winds Network Performance Monitor on windows Windows Server 2008 R2. Please share and suggest links related to this.
You can download the admin guide from thwack itself..under product forums u will find it.
Thanks for the reply,
I am not finding the admin guide under product and forums. Can you please let me know, where i can find the admin guide.
Here is the admin guide, which can also be found on our NPM Library & Support page.
Here are a couple of suggestions from the School of Hard Knocks.
Hope this helps.
Andy McBride
Network Management Engineer
Acxiom
Production installation
Thanks a lot for all the information.
We are actually setting up SQL Express on the Solar winds DB Server. Is there any steps that needs tp be followed for SQL express edition. Its a remote DB. Any configuration will i get it . Sorry. This is our first project on Solar Winds. Kindly suggest
Our Architecture,
Nagios OS:Win 2k12 R2 DC and remote database will be SQL Express. Please suggest and share, if any document. Details like connecting SQL express DB to Nagios server. Please suggest
Although SQL Express can be used due to it's limitations it's advised to use a full version of SQL what other modules are you going to install besides NPM?
http://www.solarwinds.com/documentation/Orion/docs/OriondbBestPractices.pdf
We are only installing NPM. Please let me know SQL express edition will be fine or we need to go with SQL enterprise edition.
Unless you are only going to be monitoring an extremely small environment you will most likely need to use a paid edition of SQL. From MS:
-Marc Netterfield
You can find all the Training and required documents here for each section .
Plan your production deployment
NETWORK PERFORMANCE MONITOR (NPM) https://thwack.solarwinds.com/docs/DOC-1108SERVER & APPLICATION MONITOR (SAM) https://thwack.solarwinds.com/docs/DOC-1107NETWORK CONFIGURATION MANAGER (NCM)https://thwack.solarwinds.com/docs/DOC-1106FIREWALL SECURITY MANAGER (FSM) https://thwack.solarwinds.com/docs/DOC-170941NETFLOW TRAFFIC ANALYZER (NTA)https://thwack.solarwinds.com/docs/DOC-1104WEB PERFORMANCE MONITOR (WPM)https://thwack.solarwinds.com/docs/DOC-1098IP ADDRESS MANAGER (IPAM)https://thwack.solarwinds.com/docs/DOC-1105VOIP & NETWORK QUALITY MANAGER (VNQM)https://thwack.solarwinds.com/docs/DOC-1103USER DEVICE TRACKER (UDT)https://thwack.solarwinds.com/docs/DOC-1099
STORAGE RESOURCE MONITOR (SRM)
https://thwack.solarwinds.com/docs/DOC-1100
FAILOVER ENGINE (FOE) - UPDATED SEPTEMBER
https://thwack.solarwinds.com/docs/DOC-170942
NETWORK TOPOLOGY MAPPER (NTM)
https://thwack.solarwinds.com/docs/DOC-170944
SOLARWINDS LAB (VIDEOS)
https://thwack.solarwinds.com/community/labs_tht/solarwinds-lab
