SQL Query for Inventory Report
I'm trying to get a SQL query that lists all the nodes and their IPs, serials etc, however, the issue is that I want it to list also switch stacks and their members with their serials, not have them all as one node (Inventory purposes), I found an existing report that already has the following query but it's in swql and it also doesn't include custom properties and that's something I need:
SELECT OrionNodes.Caption, OrionNodes.DetailsUrl, OrionNodes.Status, OrionNodes.ChildStatus, NcmEntityPhysical.EntityName, OrionNodes.IP_Address, NcmEntityPhysical.EntityDescription, NcmEntityPhysical.Serial, NcmEntityPhysical.Manufacturer, NcmEntityPhysical.Model, NcmNodeProperties.NodeComments, OrionNodes.SysName, OrionNodes.NodeDescription, OrionNodes.Location, OrionNodes.Contact, OrionNodes.MachineType, OrionNodes.LastBoot, OrionNodes.IOSVersion
FROM NCM.NodeProperties AS NcmNodeProperties
INNER JOIN Orion.Nodes AS OrionNodes ON NcmNodeProperties.CoreNodeID=OrionNodes.NodeID
LEFT JOIN NCM.EntityPhysical AS NcmEntityPhysical ON NcmEntityPhysical.NodeID=NcmNodeProperties.NodeID AND (NcmEntityPhysical.EntityClass='3' OR NcmEntityPhysical.EntityClass='chassis(3)')
WHERE OrionNodes.Vendor='Cisco'
order by OrionNodes.Caption
How do I come up with something like this using SQL and also include custom properties in it?
  • Hi tigerr,
    Adding the custom property is this SWQL query is quite easy.
    Add this 'OrionNodes.CustomProperties.CP1' & replace CP1 with the name of your custom property.
    If you have multiple, just add more ;-)
    To get you started with your SQL query: (Replace CP1, CP2 with real values/names)
    SELECT
    NPM.Caption AS 'Name'
    , NPM.Vendor AS 'Manufacturer'
    -- Values of Custom Properties in NPM
    , NPM.CP1 AS 'CP1-Name'
    , NPM.CP2 AS 'CP2-Name'
    , NCMEP.Model AS 'Model number'
    , NCMEP.Serial AS 'Serial number'
    -- Convert EOL date to ISO format (ex 2021-01-01)
    , LEFT(CONVERT(varchar,EndOfSupport,120),10) AS 'Retire Date'
    FROM
    NCM_NodeProperties AS NCMNP
    INNER JOIN
    Nodes AS NPM
    ON NCMNP.CoreNodeID = NPM.NodeID
    LEFT JOIN
    NCM_Entity_Physical AS NCMEP
    ON (NCMEP.NodeID = NCMNP.NodeId AND NCMEP.Class = 3)
    WHERE
    NPM.Vendor = 'Cisco'
    If you want to know what is in a certain database table via SQL --> Create a report in Solarwinds or use the SQL tools on your server & use 'SELECT * FROM DataBaseTableName'
    Be carefull with the NCM_EntityPhysical table --> add ' WHERE Class = 3' to the query
    Hope this helps.
    If so, please mark this answer as Verified.
    Wkr,
    alain_p
  • Thank you the SWQL part worked great!
    However, I couldn't get the SQL part to work properly since it's missing all the stuff from my original request and the model/serial number values are actually not populating, seems like the table reference is different.
  • Hi
    Could you please share a bit more details of what is missing / not working?
    On what version are you for NPM & NCM?
    Tables used are Nodes, NCM_NodeProperties & NCM_Entity_Physical
    Maybe you could break the SQL into little pieces to get an idea where the DB tables are different.
    Node status & a clickable URL for a node are not in the SQL query.
    Please try these 2 SQL queries in a report. Replace 'X' by an existing node number.
    SELECT
    FROM
    Nodes AS NPM
    WHERE
    NPM.NodeID = X
    SELECT
    FROM
    INNER JOIN
    Nodes AS NPM
    LEFT JOIN
    WHERE
    -- NPM.Vendor = 'Cisco'
    NPM.NodeID = X
    Good luck!
    Wkr,
    alain_p
