I've got a few questions around how Orion Netflow Traffic Analyser handles MPLS Netflow and its suitability as a product for our network environment.
I've attached a (very) high-level diagram that shows a basic overview of our network topology. Essentially there is a core network of MPLS PE routers (Cisco 6509s running 12.2(33)SXI3) that each have multiple (over a hundred in some locations) edge CE routers attached (Cisco 3550s, 3560s & 3750s) running VRF-lite and potentially multiple VRFs.
All PE routers are dual-homed between two 'key' core routers and the traffic flowing through the MPLS interfaces on those two routers represents the majority of traffic on the network (with the obvious exception of traffic between two CE sites attached to the same PE). Some of the PEs just represent points-of-presence for the aggregation of sites but others are also data centres and the network is managed in-house, i.e. the MPLS network is not provided by a commercial service provider.
What I'd like to know is whether I can export the (ingress/egress/both?) Netflow information associated with the MPLS interfaces on PE 1 and PE 2 into Orion NTA (around 20 interfaces or so) and are there any compromises by doing this, i.e. how does NTA display data associated with different VRFs, will any data be missing from the Netflow record, etc?
Is the alternative collecting the ingress flows on all the non-MPLS interfaces on the PEs from the CEs (which would represent hundreds of interfaces)?
An example of one of the PE MPLS interfaces is:-
interface GigabitEthernet9/1
description *** 1 Gig Fibre to xxxxxxxxx ***
mtu 9216
ip address 10.x.x.x 255.255.255.252
ip pim sparse-dense-mode
ip router isis
mls qos trust dscp
mpls label protocol ldp
mpls ip
no isis hello padding
end
with a interface to one of the CE routers looking something like this:-
interface GigabitEthernet1/9
description *** Site A ***
no ip address
speed 10
duplex full
interface GigabitEthernet1/9.2962
description *** Site A management network connection***
encapsulation dot1Q 2962
interface GigabitEthernet1/9.4059
description *** Site A VRF1 ***
encapsulation dot1Q 4059
ip vrf forwarding VRF1
interface GigabitEthernet1/9.1793
description *** Site A VRF2 ***
encapsulation dot1Q 1793
ip vrf forwarding VRF2
Any advice on the subject would be gratefully received.
thanks
Matthew
