Custom Query resource widget to display an inventory of SolarWinds/Orion Maps:
The following columns are displayed:
- Map Creator
- Map Name
- Entity Count
- Created Date (Local Time)
- Last Updated (Local Time)
The complementary search query has also been provided. It allows you to search by either the Map Creator's account name or the Map's Name.
If you'd like to enable search:
- Copy the same query to the Search Query field
- Remove the double-dash from the beginning of the
WHERE clause
Inspired by List of Maps by @KMSigma.SWI.
