Allows you to manually upload custom properties. Works in conjunction with the Download Custom Properties script.
You can do the same through the GUI but on version 2020.2 we had issues where Custom Property import failed so we used this script to get the imports to run.
The .CSV file used should be in this format.
| NodeID | IPAddress | Caption | CustomProperty1 | CustomProperty2 | CustomProperty3 | CustomProperty4 | CustomProperty5 | CustomProperty6 | CustomProperty7 | CustomProperty8 | |
CustomProperty9
