Seems I can't not find the widget anymore to add to new summary pages. I have it on a different summary page, I am using for nodes. Has this been removed? Currently running 2026.2.1
Not showing on Classic, Type, or Feature (Group By)
Support confirmed this is a bug (OO-67653). Here are the workaround steps they provided. I've tested this in my lab, and I was able to add the widget back.
Before applying:
Program Files
WEBROOT
dir /S /B C:\Resources.config
Elevated Command Prompt, in this exact order:
set WEBROOT=C:\Program Files\SolarWinds\Orion\Webmkdir "%WEBROOT%\Orion\OLM\Resources\TopXX"copy "%WEBROOT%\Orion\NetPerfMon\Resources\TopXX\Resources.config" "%WEBROOT%\Orion\OLM\Resources\TopXX\Resources.config"del "C:\ProgramData\Solarwinds\Orion\WebResourceCache.xml"iisreset
The cache file must be deleted before iisreset — the cache loads once when the web app starts, so deleting it afterwards has no effect until the next restart.
iisreset
Then close the browser completely and log in with a fresh session. Verify: Node Details → Customize Page → Add Widget → search Last XX. The widget appears under the "Top XX Lists" category.
Last XX
I'm not seeing anything like that either. Closest is "Last 25/50 events". I tried both on a summary page and a node details page, neither has it AFAIK…
It looks like this widget was moved to the node detail page and will only be visible if log monitoring is enabled, and the node has sent syslog or trap messages. Found the information in this KB - https://documentation.solarwinds.com/en/success_center/la/content/la/la-logs-widget.htm
The widget allows you to select how many logs you want display at a time, and what log level you want
Thanks for all the information.
I am still unable to locate the widget. Providing a new screen shot where I have the widget on the node details page (from previous version, when I added it; 2025 or 2026.1) but when I search for the widget now (2026.2.1) it is not there….
Also trying to add the widget in the page settings.
I agree, went and looked again on Node Details page. Finding other "Last XX" resources, as well as other "Log" related resources when I search, but not this one… When you say its there @matthew.orr , what version product are you using? I'm also on 2026.2.1.
Just to double check, I went into my log manager and picked a node that had just sent a log message. So log monitoring is enabled for sure, and that node had generated a log message for sure. Still same results. I even tried adding it to a different tab in case the tab I was on actually already had it. Still same results.
NTM, I can see it hiding the resource while displaying the page if set to do so, but it shouldn't hide the resource when trying to add it to a page…
I have 2026.2.1 installed. This is a screenshot from my lab instance showing the widget -
I deleted the widget and tried to add it back. It's not on the list - I guess I'm asking support how to get it back -
Confirming same issue - I have the widget on my existing Node Details page but have no way to add it to a custom Node Details view (unless I copy the existing one). Also guess I would have the same issue of not being able to add it back if I remove it from Node Details. Running 2026.2.1.
Please let us know what support advises.
Thank You
Did they say it would be fixed in a later release? Did they say which release if so?
Question is will the next Release address this Bug and fix this missing Widget without performing this workaround?
