Please allow the creation of custom reports.
There is an option to create custom reports. Under Reports, All reports, Manage Reports, Create New Report. Use Custom table and/or custom chart which will allow you to use SQL or SWQL to pull the information desired. I don't know if this option is standard across all modules so if you don't see it then you might be missing the applicable module.
@sidj2025 - I posted this in the SaaS feature request section but I think you're refering to on-premise SolarWinds each time 👍
Yes, I am referring to self hosted. I see now that you were referring to the SAAS.
@mato1964 we have now released the ability to create custom reports now - any dashboard can be converted to a custom report that can be scheduled. This is available under reports → custom reports (tab) → create report. Can you try it and provide feedback
Thanks Venky - It's hard because unlike Self Hosted table widgets do not display all the data so when you use dashboards and schedule them, you cannot see all the data.
@mato1964 enhancements coming soon in some areas such as table widget which give option to export all data and also you can increase the elements/rows you see in a page now
I see that table widgets now allow you to see all data rather than the top 10 etc.
