Recently I noticed that I cannot create tags on Network Interfaces. It made me wonder what else you cannot create tags on. PPlease can we repplicate the custom property feature over to tags in SaaS?
Hi @mato1964 Thanks for the eeedback. I am happy to share that support for tags on interfaces was released recently. You can now use these tags across mutiple areas of the platform such as alerts, dashboard widgets, entity explorer. We plan to make bulk managment of tags easier, moving closer to the use cases solved with the custom property editor. If you would like to see this as a preview once avaialable or if you would like to look at what we are working on I would be happy to set up a session with you, drop me a DM if you would like to discuss more.
Tony
@tony.johnson - Thanks for this - if the tag editor feature could be added to our tenant here at Prosperon that would be great so we can check it out etc.
