A built-in report that automatically detects: Nodes without disks monitored Nodes without interfaces Nodes without alerts This helps ensure no blind spots.
@naveensingh43 Try creating reports with the below .
SELECT n.NodeID, n.Caption, n.IPAddress, n.Vendor, n.ObjectSubType AS PollingMethodFROM Orion.Nodes nLEFT JOIN Orion.Volumes v ON v.NodeID = n.NodeID AND v.VolumeType = 'Fixed Disk'WHERE v.VolumeID IS NULL AND (n.Vendor LIKE 'Windows%' OR n.Vendor LIKE 'Linux%')ORDER BY n.Caption
SELECT n.NodeID, n.Caption, n.IPAddress, n.ObjectSubType AS PollingMethodFROM Orion.Nodes nLEFT JOIN Orion.NPM.Interfaces i ON i.NodeID = n.NodeIDWHERE i.InterfaceID IS NULL AND n.ObjectSubType <> 'ICMP' -- exclude pure ICMP nodesORDER BY n.Caption
There is no built-in report that reliably says “this node is not covered by any alert definition”; this depends on each alert’s scope logic, which is stored as XML/condition text in Orion.AlertConfigurations.
A partial approach is to look for nodes that have never had an alert status row:
SELECT n.NodeID, n.Caption, n.IPAddress, n.ObjectSubType AS PollingMethodFROM Orion.Nodes nLEFT JOIN Orion.AlertStatus s ON s.ObjectType = 'Orion.Nodes' AND s.ActiveObject = n.UriWHERE s.AlertObjectID IS NULLORDER BY n.Caption
This finds nodes that have never appeared in AlertStatus, i.e., nothing has ever actually fired for them. It does not guarantee that no alert could fire in the future, only that none has yet.
thanks for sharing.
