Dear All,
We are modern dashboard inthe tool, we want to overall infra percentage in dashboard could you please suggest the same.
Thank You
karunakar
Please review the link below; it will help you.
Modern Drill-Down Dashboard – Built for Real-Time Infra Insights - THWACK
Like this?
A KPI widget based on below SWQL query:
SELECT ROUND((100.0 * COUNT(N1.NodeID) /( SELECT COUNT(N2.NodeID) AS Nodes FROM Orion.Nodes AS N2 WHERE N2.Status NOT IN (11,9,27) -- Unmanaged, external and disabled ) ),2) AS PercentOK FROM Orion.Nodes AS N1 WHERE N1.Status=1 OR N1.Status=2 -- Up or Warning
Hi Team,
we are looking total infra percent for the customproperty field in environmen like LAN & WAN infra upercent detials.
Not sure I fully understood the question, but here is a new version where we filter to only show nodes where the custom property field "environment" is LIKE "%LAN & WAN%". Hope that at least give you the guidance to adjust according to your need:
SELECT ROUND((100.0 * COUNT(N1.NodeID) /( SELECT COUNT(N2.NodeID) AS Nodes FROM Orion.Nodes AS N2 WHERE N2.Status NOT IN (11,9,27) -- Unmanaged, external and disabled ) ),2) AS PercentOK FROM Orion.Nodes AS N1 WHERE N1.Status=1 OR N1.Status=2 -- Up or Warning AND N1.CustomProperties.environment LIKE '%LAN & WAN%'
HP ProCurve Switches Hardening check.xmlGeneral hardening for HP switches
