Anyone have any ideas on how to troubleshoot failed MIB updates? I checked the logs and it just says no. I have tried to update Prod and Lab and no go. Thanks!
Can be that the mib db file is locked by other applications.
Check this article:
MIBs database installer fails to complete successfully in SolarWinds Platform 2025.2, 2025.4 and 2026.1
Have you reviewed logs on the install?
Windows logs say "cannot install" and close. Which area of Solarwinds Logs would have this?
I tried this a no go either. It is not giving me the option to run as an Admin. I am doing this on Server 2022 for Observability.
I stopped all of the services and ran
msiexec /i "C:\programdata\Solarwinds\Installers\MIBSv2.msi"
and it worked. I will give this a try in Production when I update prod. Thanks!!!
Well it installed and now my test environment is borked. Looks like I will stay away from updating the MIB database.
Run the installer from an Administrative Powershell prompt. Sometime SW installers have issues executing with the correct permissions.
