Ability to display protocol status (BGP, EIGRP) on maps to identify false positives when links appear up but protocols fail. What are the possibilities of incorporating the routing table entity/information into intelligent maps?
This would be a good feature request. Where do those go now?
There isn’t a native “routing table layer” toggle on maps
Well, not sure most probably a feature request. Though i doubt this will surface in near future as neighnor table is volatile in nature.
I can think of a custom solution but that is high maintenance, not one time setup.
