Please can we use friendly metric names so when we get emails we don't have things like the below coming through?
sw.collector.CPULoad.AvgLoad or Stat.NativeState?
Like Self hosted these should just be 'CPU Load' and 'Status'
I believe this can also be done via edit alert under trigger actions. Choose email then the edit option for it. Under 2. Message you can add a message. I don't know if you can change what is sent using the variable, but you can put in a custom message.
Under edit you can also change the subject name for the email.
@sidj2025 are you talking about SolarWinds self Hosted or the SaaS offering? Your comment alligns with on-premise SolarWinds.
Yes, I am referring to self hosted. I see now that you were referring to the SAAS.
