HI Thwacksters and mod team There's currently no home for Squadcast in Thwack and the Squadcast community links are all broken. Hopefully there are plans to give it a home here in Thwack?
Thank you!
Good point/idea
I think it's something the THWACK team will do with the new THWACK platform.
Fingers crossed!
On the Road map for sure. Keep tuned for more details.
Hi @John.Summers any more updates on this one now the new system is "live", thank you!
This new platform would be a good home. You could create a new Header menu for other items like links to solarwinds.com, direct links to the customer portal or training calendar or Squadcast.
