Have you ever wanted a time machine? Or how about a teleporter? How many lightsabers would you have? In this episode, we list our top 5 favorite technologies featured in movies and television shows.
While we all need lightsabers to light fireworks on holidays, gimme the teleporter. I want to avoid traffic jams and the airport lobbies!
Teleporter indeed!
Cool Survey!
Replicator as with that world hunger and more would be fixed overnight
Teleporter. Would save me the 1.5 hour each way commute every time I go into the office. Would also replace the drunk taxi that seems to get me home from the pub but I would miss the kebab on the way.
I wouldn't mind my own Cylon though. I'd settle for the Number 6 version.
Number three for me
I have to go with,
