IF YOU TAKE THIS POLL BEFORE FRIDAY JUNE 9TH OR FROM THE COMMAND CENTER VS. THE MISSION, YOU WILL NOT RECEIVE MISSION CREDIT
\m/
NetFlow, NCM, PerfStack
SAM wins for me every time. Most of the work I do is with applications these days.
NPM, NTA, NCM, SAM, IPAM, WPM, SCM, UDT, LA. In fact most of the suite.
NPM
My go to has always been NPM and I expect that to be ongoing.
We use almost every module you produce. DPA and WPM are the two we are weakest at managing/fixing.
Webhelpdesk
Nit at this time
Security Event Manager
NPM, NCM
NPM is my go to for most things.
NPM, NTA, NCM, VMAN, UDT
NPM, WPM, SRM, VNQM, DPAIM, NTA, VMAN, UDT, SAM, DPA, SQL Sentry.
sam,npm,nta and wpm mostly. There are others, so it depends.
ncm
NPM, NCM, IPAM, VNQM, NTA, SAM, and LA.
DPA, NCM, SAM, NPM
NPM, NTA, SEM, and now HCO
yes
HCO, WPM
NPM,NCM
NPM, NCM & SAM
SAM, VMAN, NPM, SCM
I'm hoping to start a new position soon with a company that uses SolarWinds, but don't know which specific products yet. Glad that thwack is here to help me help them get the best use out of their system.
npm
NPM,NCM,IPAM,UDT,NTA
NPM/NCM/IPAM
The first three (SAM, VMAN, SCM) and many more SolarWinds products.
Service Desk
NPM and the toolkit
NPM, SAM
WHD
dameware
Currently have SEM deployed, looking into Service Desk and Patch Management
UDT, NTA, NPM, NCM, IPAM, SAM
SEM
NPN, NCM,SAM,NTA
NPM, NCM, SAM, NTA
Depends on the issue.
NPM, NTA, NCM
VMAN is not getting the love it deserves!!!!
Depends on the day...
NPM and NTA
NCM KIWI
NPM, NCM, SEM
NPM, NCM, WPM, SAM, NTA, LA.
