IF YOU TAKE THIS POLL BEFORE FRIDAY JUNE 9TH OR FROM THE COMMAND CENTER VS. THE MISSION, YOU WILL NOT RECEIVE MISSION CREDIT
NPM, NCM, WPM, SAM, NTA, LA.
NPM, NCM, SEM
NCM KIWI
NPM and NTA
Depends on the day...
VMAN is not getting the love it deserves!!!!
NPM, NTA, NCM
Depends on the issue.
NPM, NCM
NPM, NCM, SAM, NTA
NPN, NCM,SAM,NTA
NPM
SEM
UDT, NTA, NPM, NCM, IPAM, SAM
Currently have SEM deployed, looking into Service Desk and Patch Management
dameware
WHD
NPM, SAM
NPM and the toolkit
Service Desk
The first three (SAM, VMAN, SCM) and many more SolarWinds products.
NPM/NCM/IPAM
NPM,NCM,IPAM,UDT,NTA
npm
I'm hoping to start a new position soon with a company that uses SolarWinds, but don't know which specific products yet. Glad that thwack is here to help me help them get the best use out of their system.
SAM, VMAN, NPM, SCM
NPM, NCM & SAM
NPM,NCM
HCO, WPM
yes
NPM, NTA, SEM, and now HCO
DPA, NCM, SAM, NPM
NPM, NCM, IPAM, VNQM, NTA, SAM, and LA.
ncm
sam,npm,nta and wpm mostly. There are others, so it depends.
NPM, WPM, SRM, VNQM, DPAIM, NTA, VMAN, UDT, SAM, DPA, SQL Sentry.
NPM, NTA, NCM, VMAN, UDT
NPM is my go to for most things.
Security Event Manager
Nit at this time
Webhelpdesk
We use almost every module you produce. DPA and WPM are the two we are weakest at managing/fixing.
My go to has always been NPM and I expect that to be ongoing.
NPM, NTA, NCM, SAM, IPAM, WPM, SCM, UDT, LA. In fact most of the suite.
SAM wins for me every time. Most of the work I do is with applications these days.
NetFlow, NCM, PerfStack
\m/
