ipMonitor is a great product, that could be even better as part of the Orion suite.
imjedwa glad you think so! Curious if you could elaborate what you are looking for. I would be happy to jump on a call to discuss your needs with ipMonitor. It's Quiet...Too Quiet!
Hi jblankjblank,
We are trying to find a way to get the “Response Time”, “Transfer Speed”, and any other metrics from ipMonitor to Splunk.
We use various “Orion” products, for monitoring, and we pull the metrics we need from the Orion Database into Splunk so we can use the data side by side with other products we use for monitoring, including Splunk in some cases.
In addition to the primary issue above, it would also be nice to only have to login to a single system, like we do with other Orion products. Currently we have to log into each of our 3 ipMonitor systems manually. But this is a very minor issue.
We have been very happy with the functionality, and stability of ipMonitor, but we really need it to integrate with Splunk better, like Orion does.
Thank You for the follow up,
Thanks for the additional information! I am curious what modules you are currently running from the Orion Platform? Are you not able to pull the response time and transfer speed metrics from Orion vs using the 3 additional ipMonitors? Perhaps you can expand on your deployment a bit more?
