Stack Overflow / Server Fault: Following tags relevant to specific technologies highlights emerging issues and solutions.
I follow several tech news posts in LinkedIn on things that interest me in particular.
we have our non-mvp chat, open to all solarwinds people as well
Forums and Communities would be great.
Yep, not just one source. All over the place.
The results do not surprise me
I agree, select all!
Nowadays, social media has great power to discuss and share news.
The old blog is a good source of info, depending on the blog ofc!
Social media mostly in my case
Reddit posts, news sites, Google feed
Linkedin
Forums and Communities are great, I don't believe anything from SM
You should be able to select multiple options.
Best is News Outlets as you have Forrester and Gartner research exemplified
I think the register is a great one, I agree, I also like TLDR. Social media is a cesspool, so I avoid it.
Reddit is a good source usually. r/sysadmin knows when Teams is down before Microsoft!
Reddit and The Register
I agree with Jeremy - this needs to be a select all that apply.For myself I I mostly utilise "The Register" or occasionally I follow links via LinkedIn.
Nice
This needs to be a select all that apply...
