IF YOU TAKE THIS POLL BEFORE FRIDAY JUNE 9TH OR FROM THE COMMAND CENTER VS. THE MISSION, YOU WILL NOT RECEIVE MISSION CREDIT
NPM,NCM
HCO, WPM
yes
NPM, NTA, SEM, and now HCO
DPA, NCM, SAM, NPM
NPM, NCM, IPAM, VNQM, NTA, SAM, and LA.
ncm
sam,npm,nta and wpm mostly. There are others, so it depends.
NPM, WPM, SRM, VNQM, DPAIM, NTA, VMAN, UDT, SAM, DPA, SQL Sentry.
NPM, NTA, NCM, VMAN, UDT
NPM is my go to for most things.
NPM, NCM
Security Event Manager
Nit at this time
NPM
Webhelpdesk
We use almost every module you produce. DPA and WPM are the two we are weakest at managing/fixing.
My go to has always been NPM and I expect that to be ongoing.
NPM, NTA, NCM, SAM, IPAM, WPM, SCM, UDT, LA. In fact most of the suite.
SAM wins for me every time. Most of the work I do is with applications these days.
NetFlow, NCM, PerfStack
\m/
