Manage Nodes: Multiple "Group By" filters for custom properties (from "Manage Nodes" page)
I would like to be able to use multiple "Group By" filters from the "Manage Nodes" page, based on custom properties.
well poop!!
still no love for this...
I wish more people would want, and ask for, a more advanced, multiple group by, filter for the manage nodes view...
It sure would be nice to be able to only see/show all interfaces matching x, y, & z... similar to advanced alerts...
oh well...
Voted up, but I would say your best bet for this 'filter' would be a report.
* I may be a bit of a report hog, but sorted correctly and adjusted duplications of your reports will allow you to get the conditions you need for every area
I find the need to filter like this, on multiple fields, quite often, while managing nodes and making changes in real time.
Makes sense... I end up doing a lot of narrowing down and then manually selecting what I need. The more I think about it, the more I want it.
Come on peoples... keep thinking about it and wanting it and voting this up, up, and not away...!
Especially considering they offer this same type of grouping in a couple other fields in the product... Two that come to mind are when choosing nodes while executing a Config Change Template script in NCM as well as in the Configuration Management screen in NCM. Both offer multiple levels of grouping. Couple this feature request with these feature requests and you would have a MUCH more usable management console:
and its duplicate request here
Next would be to add in the ability to Sort, Search, Group by, and Filter like you can in the Custom Property Editor screen and I would be 1,000 times happier with Orion!
Bumping the heck out of this because it needs to happen.
nickzourdos Hopefully we will see it implemented after they get further with their new UI update project. Sure would be nice to have though...
End of week thread bump...
I also want this feature. Unless I'm doing something wrong, I just spent a couple hours re-managing about 1000 nodes with the only sort available was the Planned unmanage date. There are other nodes with different dates but I have no ability to filter them out. If the Manage Nodes page simply had filtering by any of the selected columns in addition to "group by", multiple filters would make my work so much easier and faster.
