\m/
That's correct! Expect to see points in your account from the 31st March - 3rd April
You know that's the facts!
Only Jerry can mess with Tom! Tom FTW!
It was mentioned on the main page points will be tallied and awarded at the end I believe.
Doesn't look like points are working again.
