IF YOU TAKE THIS POLL BEFORE FRIDAY DECEMBER 8TH OR FROM THE COMMAND CENTER VS. THE MISSION, YOU WILL NOT RECEIVE MISSION CREDIT
Is anyone seriously using AliBaba cloud?!
No, they only use it ironically.
Let's hope not.
In China, AWS, GCP, & Azure are blocked by the government. Alibaba is top of the line over there and it works surprisingly great. Downside, Chinese government pretty much owns it and sees everything.
We are migrating the rest of our DC to OCI.
We are migrating to OCI. Starting with our DR center.
@ahmad.nurbaitillah @anggaraputra @marthin.amellyardo @Noir @muvest
up gans
Nice
