If you currently work at a company with more than 1000 employees, this short survey is for you.
Help us understand how you define “enterprise software” and earn 250 THWACK points for a few minutes of your time.
Done. Thanks!
All set!
Done, thanks.
Done!
Done, Thanks.
Completed.
Nice survey, thanks for the points!
Completed
Completed Survey.
Smallest survey i had completed in thwack so far.
Completed. Thank you
Done
Cant participate- less then a 1000
Done.
\m/
