IF YOU TAKE THIS POLL BEFORE FRIDAY MAY 17TH OR FROM THE COMMAND CENTER VS. THE MISSION, YOU WILL NOT RECEIVE MISSION CREDIT
\m/
Not until I inherited responsibility of a Solarwinds implementation did I understand how easy it is to have redundant features in monitoring tools. The other challenge in consolidation is to make sure that you're not pigeon-holed into one specific vendor (cough Cisco cough) for the rest of eternity unless your org wants to shed tools in a real quick hurry.
NetCool
If SolarWinds Orion is not your only monitoring platform what else is being used along with SolarWinds Orion?
Yes its there now, but was not when the original email went out about the poll.
Not sure I understand why?
Anyone else have an organization big on the Zero Trust Architype? Makes it hard to have an all-in-one monitoring setup.
@jeremymayfield Top left community drop down
@ChrystalT , I cannot find the May mission, help? Not being dumb here but the Link in Thwack still shows ThwackCAMP and I do not see posts about it, can I get a link?
