If you currently work at a company with more than 1000 employees, this short survey is for you.
Help us understand how you define “enterprise software” and earn 250 THWACK points for a few minutes of your time.
\m/
Done.
Cant participate- less then a 1000
Done
Completed. Thank you
Smallest survey i had completed in thwack so far.
Completed Survey.
Completed
Nice survey, thanks for the points!
Completed.
Done, Thanks.
Done!
Done, thanks.
All set!
Done. Thanks!
