Thanks for the mission this month!
Is there a quirk going on? I voted, yet no green checkmark nor points.
No checkmark for me either.
Something goofy with the end of the month poll for sure.
Nice mission
Same no green check here.
same here
No check mark as well.
Neither!
Good Mission
Thank you for the mission this month!
I voted and no points
Voted but still shows as not done and no points awarded. Please help.
Another bug in the system... No green check just yet.
Hopefully they are able to fix the check issue! No checkmark for me either
same
Same for me - voted but no green checkmark
I didn't get a checkmark on the Monthly Mission either.
Yeah something odd is going on with some of these polls as I can't vote.
Alright!
