Alright!
We leverage NPM, SAM, and DPA data for most dashboards leveraging PerfStack.
Web Performance Monitor
PerfStack in SAM would be a lot more useful if you could include the component name when graphing metrics. If we want to graph out metrics from multiple processes, you can't tell them apart unless you graph each of them separately.
its always more than one. SAM, NPM, NTA in particular.
Also NTA and SAM data
Whichever modules are relevant at the time Most of my clients have the holy trinity, NPM, SAM, NCM, which covers most incidents, but it is handy to add in metrics from other products when it's relevant, SRM being one which pops up often.
Network Performance Monitor, Server & Application Manager, NetFlow Traffic Analyzer
I pull in as much useful data as I can about the entity I'm monitoring across all the products I have. Somehow, I'm always missing something though.
WPM, SAM and NPM
SAM, NTA, and NCM are also honorable mentions. I used to do a lot with DPA as well. and even VMAN.
Originally used it for SIP trunk monitoring, now use it for quite a lot of things. Hoping the graph aggregate feature is included soon.
