We are able to see the appliance in NPM.
I am glad that I am not alone .. I really thought more people would be using SD-WAN ... these surveys have been eye opening!!!
NPM & NCM are nice to have for monitoring, but where a WAN vendor's circuits are in play, more is needed to monitor their equipment and its configuration. They aren't always transparent to our Solarwinds deployment.
Would like to have API integration with Silver Peak, can get basic SNMP and NetFlow data now but not anything more.
We still have tin cans and string at some customers.
need more Meraki support.... SNMP is adequate at best....
alright
