New unified What We're Working On
With the release of the new unified SolarWinds Platform, we've unified our What We're Working On to a single post, go there for the latest and greatest.
Pls add support to VMware VCD environment.docs.vmware.com/.../index.html
Could you please add a way to export the Capacity Planning report, excel and pdf?
Please add support to IBM Power Virtualization
Any news on the NSX support @jvb? I'm going to have a nose at the 2023.1 RC just in case there's something spicy in there for it. Monitoring it via HCO has become a hot topic for my current public sector client
Nothing on the NSX support this time. I see you sent a direct message as well, will discuss further there. Thanks!
