We are 100% cloud for business data. We use G-Suite for User information, all out financial and other information for reservations and cameras, etc all cloud based.
Our data will span both cloud and on-premises locations (at least, until we're established in the cloud hosting environment)
Another date that doesn't give a Green check?
Alright!
