I've enabled the Example Daily Config Change Report to compare the most recently downloaded Config to the last Running Config. In every daily report, #time is logged Before & After for our Cisco 6509 core switch. I need to supress this particular comparison criteria, which ignore pattern would take care of this? Thank you.
