Greetings to the community,
I need to know how to switch from perpetual licenses to HCO. Do you have any step-by-step instructions for doing this? Thanks in advance.
Hi
Go to license manager, on the settings page.
Add the HCO/Observability license (I'm almost 100% sure all other licenses will be automatically removed then).
That's it!
Greetings, Lofstrand
Thanks for the prompt response. Should I just add the license and that's it? Wouldn't it be necessary to run the configuration wizard afterward?
Sorry, it's a bit to easy :-)Just add the license, SOMETIMES it want a restart of solarwinds services but most times that is not necessary. Could take a few minutes before all new features are fully started in the backend. But normally, just add the license and take a coffee - then enjoy the new possibilities
Would it be necessary to delete the old licenses and then add the new HCO one?
No, I don't think you need to delete the old before adding the new.
I just applied the license and then rebooted all of the servers just for good measure and everything was fine.
