Can someone share their HR Oboarding Template? My current template is missing.
Did I post in the wrong group? Anyone here?
This is the UX experience forum so probably not the right place. What product is this template missing from?
This is for Help Desk/Service Desk.
Where can I navigate to that section?
I found it... thanks for replying back!
Hey @Supersizeal , would you be willing to share yours? Below is what we're using but would love to see what others came up with.
you can always build a new one with the fields you want by navigating to the service desk> service catalog and clicking on the plus button to your top right. you input fields you would want and build a process behind it. Let me know if you have any worries concerning that
Thank you to everyone for responding.
I do however have a few more questions.
1. How do I change the required field to not required *?
2. How can I set this Service only be accessible to HR department or selected people?
3. How do I setup approvals and send notifications once tasks are completed?
Thank you
Hey @Supersizeal , happy to help!
1. To change the field from required to not required, Go to the Service Catalog item with the field you'd like to update and open it. Hover over the field and you should see ellipses (...), click that then "Edit", you'll see a warning screen of sorts that will tell you if that custom field is used in any other service catalog items. This is important as any changes will affect all of those. If you'd still like to edit this field, click "confirm" and on the next screen you should see a check box for "Mandatory". Save your changes with "Update".
2. To do this you'd use the Site and Department fields found in the Details portion of your catalog item. See my screenshot above but note, we didn't filter ours. The site and department fields are populated either manually or by what was included when users are synced.
3.For this, you'll use the Process section of the catalog item. This can be seen next to the details tab in my screenshot. I recommend checking out this guide under "Creating an Approval Process Workflow", for more details. https://documentation.solarwinds.com/en/success_center/swsd/content/completeguidetoswsd/servicecatalogadmin_serviceagentuser.htm#link5
