We are playing around with canned response and one that was created is ending up on WHD replies as a header above the notes.
Yes, I was also testing this today and experienced the same issue.
we found that the user forgot to change the outgoing email drop down to canned response which i believe caused the issue.
Can you share some screenshot how you have configured it ?
Because as far as I can see all test canned response i have added are not visible under ticket note conned response drop down!!
May be I am missing something
Make sure Create Template for is set to canned response
I'm experiencing the same thing. I'm following the directions, Canned Response is chosen, create message, Save. When I go to the Notes under Canned Responses nothing is showing up.
I'm not sure if you're still having this issue or not, but we also experienced this after updating to 12.8.3 + HF2. We have a ticket in with Solarwinds, so I'm hoping to get resolution very soon!
@bgibson Has this been resolved?
